ACS SE isn't bootup normaly
Feb 4th, 2010
when i am connect to it by console port,it's bootup i see bios version and it's invite me to type F2 if i want to go setup option but after that it seems to be crashed and it dont give a possibity to insert login and password.
i test with another acs SE and it give me after bootup to insert login and password.
can anybody help me.
thanks
Jatin Katyal Thu, 02/04/2010 - 09:34
  • Cisco Employee,
Saad,
What version and model we are running?
Also, did you try rebooting the box? If not please reboot and check the behaviour again.
If that doesn't work and If ACS SE gives you an option like Press F2 to specify the boot etc. Press F2 and get into bios using Password 'acs like acs1113'. And set the boot Preference as Hard drive. Save the settings and exit. I know that it is booting up from the harddrive but I want you to force it to boot from HD.
JK
Plz rate helpful posts-
