02-04-2010 09:15 AM - edited 03-15-2019 09:18 PM
Hi Everyone,
Our subscriber (2 server cluster) went down this AM. When it came back up, all the phones have re-registered with it but the PRIs are still registered to the publisher. Do I need to manually reset them or reboot the pub now? Is is because they need to have no active calls on them first?
Call Manager 4.2(3)
Thanks for your help,
Kelly
Solved! Go to Solution.
02-04-2010 09:34 AM
Hi Kelly,
Here you go
Cisco IOS gateways can maintain links to up to two backup Cisco Unified CallManager servers in addition to a primary Cisco Unified CallManager. This redundancy enables a voice gateway to switchover to a backup if the gateway loses communication with the primary. The backup server takes control of the devices that are registered with the primary Cisco Unified CallManager. The second backup takes control of the registered devices if both the primary and first backup Cisco Unified CallManager fail. The gateway preserves existing connections during a switchover to a backup Cisco Unified CallManager.
When the primary Cisco Unified CallManager server becomes available again, control reverts to that server. Reverting to the primary server can occur immediately, after a configurable amount of time, or only when all connected sessions are released.
Switchback
Switchback is the process a voice gateway uses to reestablish communication with the primary Cisco Unified CallManager server when the server becomes available again. Switchback can occur immediately, at a specified time after the last active call ends, or after a specified length of time.
MGCP Gateway Fallback
The MGCP gateway maintains a remote connection to a centralized Cisco Unified CallManager cluster by sending MGCP keepalive messages to the Cisco Unified CallManager server at 15-second intervals. If the active Cisco Unified CallManager server fails to acknowledge receipt of the keepalive message within 30 seconds, the gateway attempts to switch over to the next available Cisco Unified CallManager server.
SUMMARY STEPS
1. enable
2. configure terminal
3. ccm-manager redundant-host {ip-address | DNS-name} {ip-address | DNS-name}
4. ccm-manager switchback {graceful | immediate | schedule-time hh:mm | uptime-delay minutes}
5. ccm-manager fallback-mgcp
6. call application alternate
7. exit
8. ccm-manager switchover-to-backup
From this good doc;
http://www.cisco.com/en/US/docs/ios/12_3/vvf_c/interop/intcnf1.html
Hope this helps!
Rob
02-04-2010 09:34 AM
Hi Kelly,
Here you go
Switchback
SUMMARY STEPS
1. enable
7. exit
From this good doc;
Hope this helps!
Rob
02-04-2010 09:42 AM
Thanks Rob!
