Steven Smith Thu, 02/04/2010 - 11:30
This should be enabled by default.  Could you post your config of the UC500?  It is possible to disable it in there, but not likely that you did that.
Steven Smith Fri, 02/05/2010 - 13:46
This should be enabled by default.  Are you having a problem passing traffic or getting connectivity?
