I have problem with vpn client for widows 7 64 bits?
Feb 4th, 2010
Hello I have a Windows 7 for 64 bits, but I cant´t install the version cisco vpn client 5.
What version is available?
Ivan Martinon Thu, 02/04/2010 - 10:30
There is still no VPN Client from Cisco that is supported on 64Bit platforms, you would need to use the anyconnect client or use a 3rd party client that might be out there.
pudawat Fri, 02/05/2010 - 10:55
Agreeing with Ivan that Cisco has still not released a client for Windows 64 bit.
Although there are lot of freeware clients available to download such as Shrew, Safenet etc that support 64 bit OS
Phillip Remaker Fri, 02/19/2010 - 12:03
February 18, 2010
Due to popular demand, the Cisco VPN Client v5.0.7 open beta is now available!
In addition to serving as a general maintenance release, the Cisco VPN Client 5.0.7 beta is compatible with Windows 7 & Windows Vista 64-bit environments.
A 64-bit specific compatible image is available for installation on these platforms.
Please have communicate feedback (both positive and problems) to [email protected].
Key Capabilities available for Beta Testing:
New Platform support – Windows 7 & Windows Vista 64-bit platform compatibility
Software Access: http://tools.cisco.com/support/downloads/go/Redirect.x?mdfid=281940730 (under 5.BETA)
Software is available for download by any customer with a Cisco.com SMARTnet™ enabled login.
Release Notes will be available next week via a link once the download image is selected.
There are currently no plans to support Windows XP 64 bit in the VPN client.
