SQL Query for CDR
Feb 4th, 2010
Any SQL query guru who can help me with this?
The issue is that the process that was set up to gather information regarding CDR’s failed for a couple of weeks and now I am tasked with recovering that data into Equitrac, our time and billing server.  The data gets pulled into the SQL server on the CM1_PUB into the ART database.  From there it gets pulled out into a structure by a program called Facecollate and put into a useable structure for Equitrac. When I look at the authors of the SQL database that would have configured this system I see the following:
- usage EXEC Proc_WeeklyUtilizationOnDemandGen DATETIME INParameter,DATETIME INParameter,NVARCHAR OUTPamrameter
-- INT INParameter,INT OUTPUTParameter,INT OUTPUTParameter
-- drop proc Proc_WeeklyUtilizationOnDemandGen
Name            Proc_WeeklyUtilizationOnDemandGen
Environment     SQL Server 7.0
Functionality   Generate Weekly utilization report
Parameters      Input  : DATETIME - Value of From Date
                                Input  : INT - No Of Days
                Input  : NVARCHAR - Where Condition for the Query
Called Procs    Proc_WeeklyUtilizationBaseOnDemandGen
Assumptions     None
- usage Exec Proc_LoadCdrCmrData IntINParameter IntOutParameter
-- drop proc Proc_LoadCdrCmrData
Name            Proc_LoadCdrCmrData
Functionality   Loads CDR and CMR data from CCM database to ART database
Parameters      Input  : Int - Value of load id
                Output : Int - Return value
Called Procs    None
Assumptions     None
