NAC 4.7.1 CAS CAM Login issues
Feb 3rd, 2010
I upgraded from 4.5.1 to 4.7.1. I am having trouble with the communication between the CAS and the CAM
Here is an outline of the issue
1.       After Authentication, DHCP, ACS ok, WALL !!!
2.       Nac Online Users = 0
3.       Ping the CAM HA service ip
          Client = NO
          CAS = Yes
4.       Things are broken at the moment where the Agent/Web Broswer has to communicate with the Nac Manager… it just times out.
5.       Attached are pics of where it hits the 1. wall and the 2. error that pops up.
Notes
Cam Service IP Web UI > Cas Service IP is connected
Certs from the Cam imported into TCA on Cas and vice versa @ ver 4.5.1 then upgraded
DNS working
Login & remediation was working with ver 4.5.1
Any help would be greatly appreciated
Thank you Kindly
kysersosai Thu, 02/04/2010 - 11:31
Desperately I decided to check everything et voila FIREWALL. With 4.7.1 the CAS needs access to the DNS server. I’m not sure exactly why. It was a fast one liner in the firewall among all the logging but it was the CAS being denied access to the DNS? Added the rule BANG all is good.
The problem was the login works (inconsistently) for a few moments right after I upgraded or changing the cert… this really was misleading. Just got hung up on the cert being the problem.
If anyone can tell me why the CAS need to talk to the DNS server i'd appreciate it
Cheers
Related Content
