cuci moc fails "Invalid CCMCIP authentication server configuration"
Feb 4th, 2010
Installed the cuci moc add-in for my OCS R2 client but when trying to connect it fails.
The server status notification popup shows the following message:
Unknown Error.
[DeviceAdaptorInitiazationFailed] Invalid CCMCIP authentication server configuration. [1200]
Any help is welcome.
Thx
erwvan Mon, 02/08/2010 - 02:59
Hello Michael,
thank you for pointing me into the right direction. The document is very helpfull and noticed that I had to do some more configuration.
That said, I went thru the instructions and checked the registry entries for the CSF but I cannot find them in my registry.
will try to install on a seperate system as well see if there is any difference.
thx
erwvan Wed, 02/10/2010 - 04:54
Issue has been resolved.
I downloaded the latest version of the cuci-moc software which only included the software.
The previous version 7.1.2.zip also included a cucimoc-Admin-ffr.7-1-2.zip, which has the Administration Toolkit.
This toolkit also included registry update and .adm files for policy setting.
   CUCIMOC-CUCSFAdminData_GroupPolicy.reg
   CUCIMOC-CUCSFAdminData_GroupPolicy.adm
I am now able to connect and can toggle between softphone and deskphone.
Thx for your support,
Related Content
