LMS 3.2 CDA job status cleanup
Feb 4th, 2010
Using LMS 3.2. In the System Portal view, the Job Information Status includes some very old jobs that were run prior to upgrade to LMS 3.2. the status of these jobs is "cancelling". They are CDA jobs such as "CDA job from Device Center" or "CDA job due to Device Add". Is there a way of purging such info?
Also, the Log Space Usage window and the critical message Window continously show "Loading" and never change. I would like some advice on where to look to correct this.
Joe Clarke Fri, 02/05/2010 - 10:35
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
If the CDA jobs are not in a completed state, the only way to remove them will be to purge them directly from the cmf database.  TAC needs to help you with this.  The portlet problem could be due to a bad patch, or there may be some other issue visible in the CSPortal.log.
