02-04-2010 03:16 PM - edited 03-19-2019 12:24 AM
Here's an easy one for somebody...
I rec'd a request to setup an extension that calls can be transferred to internally that does the following:
The caller will hear a prerecorded product information message. then the system should hang up.
There's no requirement for a voicemail box or a physical phone.
Would anyone be able to provide detailed instructions or refer me to a website that has the procedure?
Thanks in advance for the help... BTW, we're running Unified Call Mgr version 6.1.2.1113-2
02-04-2010 04:14 PM
Hi -
If you have Unity or Unity Connection it is really easy. Assuming you have one or the other:
1. In CUCM on the directory number config forward all calls to voicemail. Include the voicemail profile on the DN config.
2. Create a call handler with the same extension as the extension number that is forwarding to voicemail.
3. Set the schedule to All Hours.
4. Record a greeting you want callers to hear.
5. Set the After Message action to Hang Up. The default is to take a message.
6. Test and you should be OK.
Hope this helps! Ginger
02-05-2010 06:27 AM
Hi Forrest,
Just to add one small note to the great tips from my friend Ginger (+5 points "G")
For the "virtual" portion config DN in CUCM use a CTI-RP to setup your new
Directory Number. As Ginger points out this can then be set for CFWDALL
to the Unity or Unity Connection Pilot # to get this show on the road
Cheers!
Rob
