How do I repair/replace the 7960 Stand Lock?
Kelly Dodd Tue, 02/09/2010 - 15:28
To remove it, turn the phone over, lay down the stand and then locate the 2 tabs on the stand chassis.  The tabs are located at the "bottom" of the stand (the narrow part of the stand) and you use a medium flat blade screwdriver to push them back.  They are located about a quater inch from each end.
