Need clarification on CCIE Lab
Feb 4th, 2010
Two things have changed in 2009.  Question and answer for 30 mins and troubleshooting for 2 hrs.  I would like to get an idea how the test is run.  My guess, they will start you on Q&A, then troubleshooting.  Since the whole test is 8 hr does this means you only have 5 1/2 hrs for the actual lab?
If you finish Q&A and troubleshooting in less than 2 1/2  hrs, can you apply the time you save for the lab?
Does the Lab sections contains the same number of sections/task compare to 2008?
If the passing score is 80%, how is it split up between the 3 test (Q&A, Troubleshooting and Lab)?
If you failed the Q&A and/or the troubleshooting, do they allow you to continue on the lab?
Thank You
Roel
