Error load MIB in HUM
Feb 5th, 2010
Hi all,
I get this error when I try to load CISCO-PRODUCTS-MIB.my in HUM
"Unable to load the MIB file. Either you are trying to load an invalid MIB file or the dependent MIB files are not available in the path"
How you can see in this site http://tools.cisco.com/Support/SNMP/do/BrowseMIB.do?local=en&mibName=CISCO-PRODUCTS-MIB, this mib don't have dependencies
Could anybody help me?
Joe Clarke Fri, 02/05/2010 - 11:15
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
What version of HUM are you using?  I tested 1.2.1, and the MIB loaded just fine.  I placed it under NMSROOT/hum/mibmanager/mibcompiler/mibs, made sure casuser had access to it, then loaded it.
