Nexus 1000V - Can not see VEM in VSM
Feb 5th, 2010
We are trying the version 4.0(4)SV1(2) and we can not see the VEM in the VSM yet. We don't see the "System Uplink" port profile assigned to a physical interface and we think that maybe this is the problem.
This is our config of port-profile
port-profile type ethernet system-uplink
  vmware port-group
  switchport mode trunk
  switchport trunk allowed vlan all
  no shutdown
  system vlan 22-23
  state enabled
port-profile type vethernet vlan-22
  vmware port-group
  switchport mode access
  switchport access vlan 22
  no shutdown
  state enabled
port-profile type vethernet vlan-23
  vmware port-group
  switchport access vlan 23
  no shutdown
  state enabled
svs-domain
  domain id 50
  control vlan 22
  packet vlan 23
  svs mode L2
Thank you! Celeste
kanglee Sun, 02/07/2010 - 12:09
Simon,
This issue can be caused by multiple reasons but there are few things to check first at initial configuration. Your vem, esx host, has to communicate to vsm on control vlan. This is like backplane on your switch. One way to verify end-to-end connectivity for control vlan is creating secondary service console interface with control vlan port-group. This doesn't have to be routable. Just between hosts, especially the host that has vsm and other hosts with vem.
Once that is verified then you can do the same thing for packet vlan to make sure. Next step is to check if you have installed the vem installation. You can login to esx host as root privilege and do vem status. Then it will tell you if vem is running or not. Also, you can check the license issue as well
N1KV-1# sh module vem mapping
Mod     Status          UUID                                    License Status
  3      powered-up     fe95c396-6c97-11d9-1111-00000000004f    licensed
  4      powered-up     fe95c396-6c97-11d9-1111-00000000006f    licensed
  5      powered-up     fe95c396-6c97-11d9-1111-00000000007f    licensed
  6      powered-up     fe95c396-6c97-11d9-1111-00000000005f    licensed
  7      powered-up     fe95c396-6c97-11d9-1111-00000000003f    licensed
  8      powered-up     fe95c396-6c97-11d9-1111-00000000002f    licensed
[[email protected] ~]# vem status
VEM modules are loaded
Switch Name    Num Ports   Used Ports  Configured Ports  MTU     Uplinks
vSwitch0       32          1           32                1500
DVS Name       Num Ports   Used Ports  Configured Ports  Uplinks
SJ-N1KV-1      256         58          256               vmnic0,vmnic1
VEM Agent (vemdpa) is running
c_simon Tue, 02/09/2010 - 12:28
Hi Kang,
We test the connectivity with our Packet and Control Vlans, and it works fine, but we still not seeing the VEM in VSM
The sh module vem mapping shows nothing:
VSM-1000v# sh module vem mapping
VSM-1000v#
And the vem status command in ESX shows that the agent is running and loaded.
VSM and VM are running on the same ESX host.
Thank you!
Celeste
kanglee Tue, 03/09/2010 - 05:45
If you are sure control, packet vlan have configured correctly, then you can try to remove that host from dvs and add back in. It is better to choose the vmnic when you add the host to the N1K rather than adding it later. N1K needs at least one vmnic to connect to vsm. This has to be mapped on your system uplink.
Then you can try to restart the host or vem restart on the host.
thanks
jean.kobben Thu, 10/07/2010 - 10:36
we do have the same Problem.
Installed is the Nexus1000v.4.0.4.SV1.3a
The latest VEM (VEM410-201007311) is installed on ESXi4.1
Packet VLAN and Control VLAN are testet. Communication works fine.
The Hosts don't register to the VSM.
VSM Logging says:
2010 Oct  7 17:05:24 DF-ESX-V-01-PRZ %VMS-5-DVS_HOSTMEMBER_INFO: A host with name=[HOST2] and uuid=[a62ba661-7
74b-3f10-0069-00238b428590] is added to the dvs. The host is not found  as a module in the VSM configuration.
We have Installed the VEM manually, per VUM and automaticaly per VUM.
Jean
sachthak Thu, 10/07/2010 - 10:46
Is your VSM running on the N1KV port profiles vlan-22 and vlan-23 for the control and packet interface? If so, you'll have to make both of those system vlans in the port profile as well.
Also have you added your pnic to the uplink port profile from the DVS networking view on the host?
sachin
jean.kobben Thu, 10/07/2010 - 11:36
Hello Sachin,
we use VLAN 900 and 901 for Packet and Control.
Both VLANs are defined as system vlans.
Jean
sachthak Thu, 10/07/2010 - 11:38
Could you post the port profile config for your uplink/veth profiles, svs connection and svs domain if possible?
Also could you paste the output of vemcmd show version on the host.
thanks,
sachin
jean.kobben Thu, 10/07/2010 - 11:51
N1Kv# sh svs domain
SVS domain config:
  Domain id:    1
  Control vlan: 901
  Packet vlan:  900
  L2/L3 Control mode: L2
  L3 control interface:  NA
  Status: Config push to VC successful.
N1kv# sh svs connections
connection duesseldorf:
    ip address: 172.34.57.16
    remote port: 80
    protocol: vmware-vim https
    certificate: default
    datacenter name: Harvard
    DVS uuid: 61 de 1f 50 8d 07 26 fa-2a fa de 91 4b bc c9 d8
    config status: Enabled
    operational status: Connected
    sync status: Complete
    version: VMware vCenter Server 4.1.0 Build-258902
DF-ESX-V-01-PRZ# sh port-profile
port-profile Access-I_ESX-VM-NET_MGT
  description: ## I_ESX-VM-NET_MGT ##
  type: vethernet
  status: enabled
  capability l3control: no
  pinning control-vlan: -
  pinning packet-vlan: -
  system vlans: none
  port-group: Access-I_ESX-VM-NET_MGT
  max ports: 32
  inherit:
  config attributes:
    switchport access vlan 2014
  evaluated config attributes:
  assigned interfaces:
port-profile Access-I_ESX-VM-Net_PUB
  description: ## I_ESX-VM-Net_PUB ##
  type: vethernet
  status: enabled
  system vlans: none
  port-group: Access-I_ESX-VM-Net_PUB
  max ports: 32
  inherit:
  config attributes:
    switchport access vlan 2001
port-profile Access-I_WIN-NET_PRI
  description: ## I_WIN-NET_PRI ##
  type: vethernet
  status: enabled
system vlans: none
  port-group: Access-I_WIN-NET_PRI
  max ports: 32
  inherit:
  config attributes:
    switchport access vlan 2100
port-profile Access-Z_IKB_VSERV7-8
  description: ## VSERV7-8 bzw. public ##
  type: vethernet
  status: enabled
  system vlans: none
  port-group: Access-Z_IKB_VSERV7-8
  max ports: 32
  inherit:
  config attributes:
    switchport access vlan 310
port-profile Access-Z_IKB_VSERV7-8neu
  description: ## VSERV7-8neu bzw. public ##
  type: vethernet
  status: enabled
  system vlans: none
  port-group: Access-Z_IKB_VSERV7-8neu
  max ports: 32
  inherit:
  config attributes:
    switchport access vlan 311
port-profile InfraAccess-FT
  description: ## FT ##
  type: vethernet
  status: enabled
  system vlans: none
  port-group: InfraAccess-FT
  max ports: 32
  inherit:
  config attributes:
    switchport access vlan 902
port-profile InfraAccess-I_ESX-NET_MGT
  description: ## I_ESX-NET_MGT ##
  type: vethernet
  status: enabled
  system vlans: none
  port-group: InfraAccess-I_ESX-NET_MGT
  max ports: 32
  inherit:
  config attributes:
    switchport access vlan 2010
port-profile InfraAccess-VMotion
  description: ## VMotion ##
  type: vethernet
  status: enabled
  system vlans: none
  port-group: InfraAccess-VMotion
  max ports: 32
  inherit:
  config attributes:
    switchport access vlan 903
port-profile InfraAccess-VSM-Control
  description: ## VSM-Control ##
  type: vethernet
  status: enabled
  system vlans: none
  port-group: InfraAccess-VSM-Control
  max ports: 32
  inherit:
  config attributes:
    switchport access vlan 901
port-profile InfraAccess-VSM-Packet
  description: ## VSM-Packet ##
  type: vethernet
  status: enabled
  system vlans: none
  port-group: InfraAccess-VSM-Packet
  max ports: 32
  inherit:
  config attributes:
    switchport access vlan 900
port-profile Unused_Or_Quarantine_Uplink
  description: Port-group created for Nexus1000V internal usage. Do not use.
  type: ethernet
  status: enabled
  system vlans: none
  port-group: Unused_Or_Quarantine_Uplink
  max ports: -
  inherit:
  config attributes:
    shutdown
    shutdown
port-profile Unused_Or_Quarantine_Veth
  type: vethernet
  status: enabled
  system vlans: none
  port-group: Unused_Or_Quarantine_Veth
  max ports: 32
  inherit:
  config attributes:
    shutdown
    shutdown
port-profile Uplink-Customer
  description: ## Uplink zu DF-ESX-C-01 ##
  type: ethernet
  status: enabled
  system vlans: none
  port-group: Uplink-Customer
  max ports: -
  inherit:
  config attributes:
    switchport trunk allowed vlan 310-311,2001,2100
    no shutdown
    no shutdown
port-profile Uplink-FT
  description: ## Uplink zu DF-ESX-B-01 FT ##
  type: ethernet
  status: enabled
  system vlans: none
  port-group: Uplink-FT
  max ports: -
  inherit:
  config attributes:
    no shutdown
    no shutdown
port-profile Uplink-Management
  description: ## Uplink zu DF-ESX-B-01 Mgmt ##
  type: ethernet
  status: enabled
  system vlans: 900-901,2010
  port-group: Uplink-Management
  max ports: -
  inherit:
  config attributes:
    switchport trunk allowed vlan 900-901,2010,2014
    no shutdown
    no shutdown
port-profile Uplink-VMotion
  description: ## Uplink zu DF-ESX-B-01 VMotion ##
  type: ethernet
  status: enabled
  system vlans: none
  port-group: Uplink-VMotion
  max ports: -
  inherit:
  config attributes:
    no shutdown
    no shutdown
vemcmd show version
VEM Version: 4.0.4.1.3.1.0-2.0.3
VSM Version: 4.0(4)SV1(3a)
System Version: VMware ESXi 4.1.0 Releasebuild-260247
sachthak Fri, 10/08/2010 - 16:59
Hi Jean,
Based on the port profile names, I am guessing that the VSM is on the VEM with InfraAccess-VSM-Control and InfraAccess-VSM-Packet as the control and packet port groups for the VSM VM. If so, the vlans on these port profiles 901/900 should be defined as system vlans as well.
Hope this helps
Sachin
jean.kobben Tue, 11/02/2010 - 06:24
Hi Sachin, sorry for responding so late.at the moment we have Standard VS.the VSM is connected to 3 Portgroups; Management, Control and PacketThe VLAN IDs of Packet and Control are corresponding the VLAN IDs of the VSM. Because no host is connected to the VSM, we can't use InfraAccess-VSM-Control and InfraAccess-VSM-Packet.We're still at the beginning :( RegardsJean
Last Update.
i configured the system vlans on the corresponding portgroups on the VSM.
No Connection :(
jean.kobben Tue, 11/09/2010 - 03:00
Hi Sachin,
after adding "channel-group auto mode on" to all Uplink Portgroups, the VEMs registred.
Jean
In case anyone else runs across this thread (as I did in troubeshooting a similar issue) I wanted to share what fixed it for me.  In my case, I had accidentally added the ESX Host to the wrong VSM.  I removed the host from the VSM and added it to the correct one, but it still seemed to be broken.  I followed all of the steps in this document:
http://www.cisco.com/en/US/docs/switches/datacenter/nexus1000/sw/4_0/troubleshooting/configuration/guide/trouble_5modules.html#wp1192946
However, everything checked out according to the document.  As a last resort, I decided to remove the ESX Host from the vDS and uninstall the VEM using the command "vem-remove -d" at the ESX host.  I then added the host back to the correct vDS, and the issue was resolved!  I had removed and added the host back many, many times, so I am certain the uninstalling the VEM and having VUM reinstall it is what resolved the issue.  If the above Cisco document does not shed any light, uninstalling and reinstalling the VEM may be useful for you.
