Symantec end point protection compatible matrix CCM 4.1.3
Answered Question
Feb 5th, 2010
Hi to everyone,
It would be a great help if anyone guide me to find out symantec end point protection supported versions in CCM 4.1.3 ?
siva
Correct Answer by Brandon Buffin about 6 years 11 months ago
Here's a doc.
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/vcallcon/ps556/prod_bulletin0900aecd804be52a.html
It's several years old, but the compatibility is likely not being updated due to the fact that CCM 4 is EOS/EOL.
Hope this helps.
Brandon
Overall Rating: 5 (1 ratings)
gogasca Fri, 02/05/2010 - 10:31
CSCsm81882
Current config. docs are not consistent in their configuration instructions. The all should include the following:
- CPU throttling to no more than 10% CPU usage
- Exclusion of ALL trace dir, On-Access & Scheduled
- Exclusion of IDS/CSA dir, On-Access & Scheduled
- Exclude trusted 3rd party dir, On-Access & Scheduled
- Exclude database directory, On-Access & Scheduled
- Exclude Pagefile dir, On-Access & Scheduled
- Limit the size of compressed file scanning
- Disable Script Scanning, On-Access & Scheduled
- Disable Scanning Windows Protected files, On-Access & Scheduled
- Disable Heuristics Scanning
- Disable Inheriting of policies
- Clear not definition of Cisco Support Policy
- Statement of System Scanning during low traffic period
