02-05-2010 07:08 AM - edited 07-03-2021 06:28 PM
All,
Is there any way to do a port span or tap of all traffic going to and from a WiSM? You can't seem to monitor the port channel that goes into the controller.
Jason
Solved! Go to Solution.
02-05-2010 07:41 AM
Sure, you can set the port-channel interface as the source of the monitor session.
lab1sup720ip1(config)#monitor session 1 source interface ?
FastEthernet FastEthernet IEEE 802.3
GigabitEthernet GigabitEthernet IEEE 802.3z
Port-channel Ethernet Channel of interfaces
02-05-2010 07:41 AM
02-05-2010 08:30 AM
I will meet with security on monday and see if it works.
It did kick out this error:
msndc-ssw1(config)#monitor session 1 source interface po417
% Monitor Session with Service Cards Port-Channel will not be nvgened
