RV082 - Subnet /18 possible?
floriangrehl
Is there any way to get an Subnet larger than /24 to the primary VLAN? The Drop-Down only allows to select /24 and smaller.
Using secondary Subnet is no solution because i need a port forwarding rule to the /18 Subnet.
jasbryan
Level 6
Level 6
None of the Small Business routers will go below /24.
   Jason
