EIGRP Summarization
nsousa1984
I am having trouble configuring EIGRP summarization. Attached is the network diagram. I am using the CCNA virtual lab to configure this.
Router configs:
R1
    --snip--
    interface Serial0/0/0
      ip address 192.168.1.34 255.255.255.252
      no ip directed-broadcast
    interface Serial0/0/1
      ip address 192.168.1.37 255.255.255.252
      clockrate 2000000
    --snip--
    R1#sh ip eigrp top
    IP-EIGRP Topology Table for AS(1)/ID(192.168.1.34)
    Codes: P - Passive, A - Active, U - Update, Q - Query, R - Reply,
           r - reply Status, s - sia Status
    P 10.10.10.8/29, 1 successors, FD is 2172416
             via 192.168.1.38 (2172416/28160), Serial0/0/0
    P 192.168.1.32/30, 1 successors, FD is 2172416
             via Connected, Serial0/0/0
    P 192.168.1.36/30, 1 successors, FD is 2172416
             via Connected, Serial0/0/1
    P 192.168.1.40/30, 1 successors, FD is 2172416
    P 10.10.10.0/29, 1 successors, FD is 2172416
             via 192.168.1.33 (2172416/28160), Serial0/0/0
    R1#
      ip address 192.168.1.38 255.255.255.252
      ip address 192.168.1.41 255.255.255.252
      clockrate 2000000
    router eigrp 1
     network 192.168.1.0
    R3>en
    R3#sh ip eigrp top
    IP-EIGRP Topology Table for AS(1)/ID(192.168.1.38)
             via 192.168.1.37 (2172416/28160), Serial0/0/1
             via 192.168.1.42 (2172416/28160), Serial0/0/1
    R3#
Here is one core router configuration that should be summarizing that block:
    R2 Con0 is now available
    Press RETURN to get started!
    R2>en
    R2#sh run
    Building configuration...
    Current configuration : 874 bytes
    version 12.4
    hostname R2
    boot-start-marker
    boot-end-marker
    no aaa new-model
    ip cef
    ip subnet-zero
    interface FastEthernet0/0
      ip address 10.10.10.1 255.255.255.248
      ip summary-address eigrp 1 192.168.1.32 255.255.255.240
    interface FastEthernet0/1
      no ip address
      shutdown
      ip address 192.168.1.33 255.255.255.252
      clockrate 2000000
      no ip address
      shutdown
      clockrate 2000000
    interface Serial0/1/0
      no ip address
      shutdown
      clockrate 2000000
    interface Serial0/1/1
      no ip address
      shutdown
      clockrate 2000000
    router eigrp 1
     network 10.0.0.0
     network 192.168.1.0
     no auto-summary
    ip classless
    no ip http server
    no ip http secure-server
    control-plane
    line con 0
    line aux 0
    line vty 0 4
      login
    line vty 5 1180
      login
    scheduler allocate 20000 1000
    end
    R2#
    R2>en
    R2#sh ip eigrp top
    IP-EIGRP Topology Table for AS(1)/ID(192.168.1.33)
             via null (2172416/28160), FastEthernet0/8
             via 192.168.1.34 (2172416/28160), Serial0/0/0
             via Connected, FastEthernet0/0
    R2#
R2>en
R2#sh ip route
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
       i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, * - candidate default
       U - per-user static route, o - ODR, P - periodic downloaded static route
       T - traffic engineered route
Gateway of last resort is not set
    10.0.0.0/29 is subnetted, 2 subnets
D     10.10.10.8 [90/2172416] via 10.10.10.9, 01:31:30, FastEthernet0/0
C     10.10.10.0 is directly connected, FastEthernet0/0
    192.168.1.0/30 is subnetted, 3 subnets
C     192.168.1.32 is directly connected, Serial0/0/0
D     192.168.1.36 [90/2172416] via 192.168.1.34, 01:31:30, Serial0/0/0
D     192.168.1.40 [90/2172416] via 192.168.1.34, 01:31:30, Serial0/0/0
R2#
I used a 16 block for the /30 addresses between each serial link. The starting IP is 192.168.1.33, with the network ID being 192.168.1.32.
There is complete connectivity between all devices, but it will not summarize all of the /30's into a single 16 block of .240.
I added in the "auto-summary" command on R1 and R3, and "no auto-summary" on R2 and R4 anyway but it didn't change anything. I'm not sure what I'm missing.
rais
Level 7
Level 7
You can look at this link
In addition, your IPs in 10.10.10.0/29 range seems to be out of range. Valid IPs are only from 10.10.10.1 to 10.10.10.6 for /29
Thanks.
Jon Marshall
Just labbed this up with dynamips and it works as expected ie.
if you turn on auto-summary on R2 & R4 then the 3560 switch just sees 2 entries for 192.168.1.0/24
if you use the ip summary-address eigrp .. command on the interfaces facing the 3560 then the 3560 switch sees 2 entries for 192.168.1.32/28.
So it all works as expected. Remember that you will only see the effects of summarisation on the 3560 and not on any of the other routers.
I'm assuming your 3560 is running as a L3 switch and is an EIGRP peer with R2 & R4.
Jon
