yjdabear Fri, 02/05/2010 - 11:46
  • Gold, 750 points or more
You mean you're getting those network syslogs while logged in on the LMS server? In that case, you probably have a misconfiguration in /etc/syslog.conf. Can you post /etc/syslog.conf in its entirety?
A second issue is that the device "rougrx1" has a CPU hog condition.
jorgelina.abraham Fri, 02/05/2010 - 12:23
Thanks very much!
Here the file:
[email protected] # more syslog.conf
#ident  "@(#)syslog.conf        1.5     98/12/14 SMI"   /* SunOS 5.0 */
# Copyright (c) 1991-1998 by Sun Microsystems, Inc.
# All rights reserved.
# syslog configuration file.
# This file is processed by m4 so be careful to quote (`') names
# that match m4 reserved words.  Also, within ifdef's, arguments
# containing commas must be quoted.
*.err;kern.notice;auth.notice                   /dev/sysmsg
*.err;kern.debug;daemon.notice;mail.crit        /var/adm/messages
*.alert;kern.err;daemon.err                     operator
*.alert                                         root
*.emerg                                         *
# if a non-loghost machine chooses to have authentication messages
# sent to the loghost machine, un-comment out the following line:
#auth.notice                    ifdef(`LOGHOST', /var/log/authlog, @loghost)
mail.debug                      ifdef(`LOGHOST', /var/log/syslog, @loghost)
# non-loghost machines will use the following lines to cause "user"
# log messages to be logged locally.
ifdef(`LOGHOST', ,
user.err                                        /dev/sysmsg
user.err                                        /var/adm/messages
user.alert                                      `root, operator'
user.emerg                                      *
# Added for Cisco Syslog Analyzer (begin)
local7.info             /var/log/syslog_info
# Added for Cisco Syslog Analyzer (end)
#BEGIN CSCOmd - DO NOT EDIT THESE COMMENTS OR CONTENTS CONTAINED WITHIN - local1
local1.emerg;local1.alert;local1.crit;local1.err;local1.warning;local1.notice;lo
cal1.info;local1.debug  /var/adm/CSCOpx/log/dmgtd.log
#END CSCOmd DO NOT EDIT BEFORE THIS LINE  1
[email protected] #
[email protected] #
Joe Clarke Sat, 02/06/2010 - 09:17
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You want to add local7.none to some of those other lines.  For example
local7.none;*.alert          root
Any line which has "local7.none" on it will not receive messages from the local7 facility (i.e. syslog messages from your devices).
