Music On Hold (MOH) issue after resource connection attempt.
Bill Brown
Problem:
If a agent is ready when a call comes into a queue but does not answer the call, the caller remains on hold but in silence after the failed connection.
If an agent makes himself ready while a call is holding in a queue, but does not answer the call, it stays in the queue, but hold music resumes.
Setup:
Unified CM Administrator 7.1.3.20000-2
Contact Center Express 7.0(1) SR4_Build 443
Thoughts:
I do not wish for a caller to presume that he has been disconnected.  I've thought about holding and unholding the call every minute, but do not want the caller to think the audio is choppy.  What is the best way to get this working?
Chris Deren
I am assuming you only have one select resource logic and both call scenarios follow the same path, if so this looks to be like a bug.
HTH,
Chris
Chris Deren
HTH,
Chris
Yes, I've tested this coming out of the same select resource logic.  We are planning on moving from the Cisco 4.XX series over to the newer build.  I had noticed that at times during testing the hold music would stop.  I then narrowed it down as to only occurring when the described instance occurs.  My current hold time is 150 seconds for this queue.  The Call Hold command seems to be ignored when the call tries to connect to someone ready and doesn't get them.  Perhaps a delay of one second before holding the call will fix the issue.  If what I try below works, then this is definetly a bug.
Instead of:
Call Hold
Delay 115 sec
Call Unhold
I'm going to try below in the Queued section of the Select Resource command:
Delay 1 sec
Call Hold
Delay 149 sec
Call Unhold
Adding the delay of 1 second, before placing on hold, has resolved this issue.  Seems that if an agent is ready, but does not answer the call that the first step in the queued section does not get executed.  Thanks for all your help in resolving this issue, perhaps this bug will be fixed in a future release of the contact center software.
