Encryption domain
Feb 5th, 2010
I have a quick quesiton here in genernal when you set up an encryption domain for an ipsec tunnel the subnet mask
of your encryption domain must match your source/destination subnet mask.  So for example say you have a source
of  170.132.128.0/24 and destination of 168.162.30.240/28 and you build your ecryption domain with these subnet.
now say the source end decides to change the source subnet from 170.132.128.0/24  to a 170.132.128.96/27
that mean on my encryption domain on the VPN device I also need to change it from a /24 to a/27 to match
my source otherwise if I leave my encryption domain  as a /24 when I source from the /27 the source ip will be
denied and the tunnel will not come up because it is expecting a /24 but now it see's a /27 correct?  so inorder
for me to fix this I must change my encryption domain from a /24 to a/27 to match my source subnet of a /27.
JORGE RODRIGUEZ Fri, 02/05/2010 - 15:15
  • Green, 3000 points or more
That is correct ,  encryption domain must match at both ends, if your side or other side changes network IDs  pertaining to that particular tunnel policy both ends   must update the access list accordingly in order for the vpn tunnel to successfully come up when sending traffic between the two networks.
