Hi there,
I wonder if you can help with the following issue.
Anyconnect VPN client (64 bit windows workstation) is not connecting to Cisco 870 VPN router, other VPN connections with old VPN client software (32bit windows workstation) are working fine.
Do we need any special configuration on 870 router for anyConnect VPN client to connect?
Any help to make this VPN connection work will highly be appreciated.
Best regards
Chaudhry
