CUCM 6.1.1 Logs to view configuration changes made
Answered Question
Feb 5th, 2010
Hi All,
I need urgent assistance as so many people are making changes to configuration. Is there a log file in CUCM  which provide details of when and who made changes OR saved changes as most routers & switches shows " Last NVRAM saved details" if logging is enabled correctly. There should be similar sort of feature in Call Managers as well.
I have also seen lot of user accounts defined in call manager and most those people don't work with us. I am bit reluctant to get rid of those account as I don't know if those accounts can be configured to run the services on Call Manager as it happens on window operating system that you can create service account to run some service such as MS SQL etc. IF services in Call Manager doesn't depend on END user or application users then it will be easy for me to delete the accounts not needed.
ANY ASSISTANCE PROVIDED WILL BE GREATLY APPRECIATED
Correct Answer by Jaime Valencia about 6 years 11 months ago
This has been asked plenty of times before, PLEASE SEARCH for answers
There is no native logging, the closes thing is for you to review the tomcat logs.
Linux appliances do not have any dependency between any end/application user and the services
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Fri, 02/05/2010 - 19:22
java
tcb_tcb_1975 Sat, 02/06/2010 - 01:17
Hi Java,
Thanks for your response. I am new to VoIP and have no idea where Tomcat logs are stored. Is it possible to explain in detail "how to access Tomcat logs" and level of logging it has.
Mike
