QM 2.7 Recording Issue
nlakhani18377
Hi there,
I am using QM with CUCM 7.1 & UCCX 7.0 - I believe my configuration is fine and am trying to accomplish recoding for IPPA (IP Phone Agent with 7942). I have configured SPAN on my 3560 switch (both server and phone are on the same switch with different VLAN). After the test call I checked the destination folder on the server where recording supposed to store but see nothing there...
Not sure what I am missing - I have not seen any sync issues either, all the users are visible under QM Administrator..Any help would be apprciated...
Nadir
rommel.bulan
Hi Nadir,
If you have configured the RSPAN, I assume that recording on the UCCX is working fine.
What kind of recording are you trying to implement in QM. Is it the server based recording or desktop based recording?
Rommel
Thanks for the reply Rommel - I will eventually configure RSPAN at the customer site but currently testing at the Lab with local SPAN - I am using Server based recording..
After the call I don't see any recording file at the server...Any suggestions ??
Nadir
frankly, we did not get the server based recording to work.. what we did is focus on getting the desktop recording to work..you might want to call up Cisco and they will forward you to Calabrio..they may be able to help..if i find something i will let you know..
goodluck.
