Unity 4, Alias Already Exists but can not find it
Feb 5th, 2010
When i am trying to add a new Alias to Unity, it says Alias already exist but can not find it any where in Unity.
Bradford Magnani Sat, 02/06/2010 - 07:05
Sounds like SQL already has row in the Subscriber table for this user... I would recommend opening a TAC case to get it removed.
Hope that helps,
Tray Stoutmeyer Sun, 02/07/2010 - 11:23
I think you could also use the remove subscriber properties and find this user to remove it. This tool is located in x:\commserver\utilitites\removesubscriberproperties.
Open the tool and it will look like your AD snap in. If you find the user that Unity states exists when it shouldn't and has a bunny icon next to it, you should be able to select it and delete it. It then will be totally cleared out of Unity.
Related Content
