Error while restoring LMS 2.6 backup
Feb 6th, 2010
I am getting following error while restoring ciscoworks lms 2.6 backup.
ERROR: doRestore of [Resource Manager Essentials] had some errors.
              Check the log file for details
Please check attachment for restorebackup.log file
Michel Hegeraat Sat, 02/06/2010 - 06:29
Looks like some sort of permissions problem or a file that is not found..
Are you administrator on the machine?
Does D:\WINDOWS\system32\cacls.exe exist?
[Sat Feb  6 17:04:29 2010] [ echo y| D:\WINDOWS\system32\cacls.exe backup\0\rmeng\tempDir /T /G Administrators:F casusers:F ]
Are you sure (Y/N)?The system cannot find the path specified.
ERROR: In executing echo y| D:\WINDOWS\system32\cacls.exe backup\0\rmeng\tempDir /T /G Administrators:F casusers:F
[Sat Feb  6 17:04:29 2010] ERROR: In executing echo y| D:\WINDOWS\system32\cacls.exe backup\0\rmeng\tempDir /T /G Administrators:F casusers:F
ERROR: Error in changing permission to backup\0\rmeng\tempDir.
[Sat Feb  6 17:04:29 2010] ERROR: Error in changing permission to backup\0\rmeng\tempDir
Cheers,
Michel
yusuf.ujjainwala Sun, 02/07/2010 - 21:37
Following is the output of given command.
D:\>D:\WINDOWS\system32\cacls.exe exist?
The system cannot find the file specified.
If I search for cacls.exe file in system32 it shows file is exist in the folder
