Dynamic Switch Between MAC Protocols
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin-top:0in; mso-para-margin-right:0in; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0in; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;}
Hello All,
I don’t know if the is the right place to post this question.
I’m investigating the feasibility of incorporating two access methods protocols in one LAN (CSMA/CD and Token Ring). That is based on the traffic, for example, the network could dynamically change between the two protocols.
So, is that feasible to be implemented using the modern switches or hosts LAN controller?
Thanks.
Ganesh Hariharan Sun, 02/07/2010 - 06:47
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Hello All,
I’m
two protocols.
Thanks.
Token ring protocol support was only in cisco 3900,3920 and 5000 switches which are also given a end of sales today modern switches gives a support to token rings vlan by a remote device such as a Catalyst 5000 series switch with Token Ring connections could be managed from one of the supported switches. Switches running VTP Version 2 advertise information about these Token Ring VLANs:
Token Ring TrBRF VLANs
•     Token Ring TrCRF VLANs
Check out the below links for token ring vlan support in 2960/3560/4500 switches hopw that clear out your query !!
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_25_see/configuration/guide/swvlan.html#wp1035492
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.1_19_ea1/configuration/guide/swvtp.html
http://www.cisco.com/en/US/tech/tk389/tk689/technologies_configuration_example09186a008009478e.shtml
and check out the below link for 3900 and 3920 supported for token ring which is end of sale
http://www.cisco.com/warp/public/cc/pd/si/casi/ca3900/prodlit/1644_po.htm
Hope that help
If helpful do rate the post
Ganesh.H
