SA 520 W Painfully slow
I recenly installed an SA 520 W for client using Verizon DSL (3 meg down). This box replaced an old Firebox firewall. Prior to the switch, download speeds were close to the advertised 3 meg. Now, with the SA 520 in place, we are receiving roughly 300kbps down with a massive ammount of latency. There have been no other changes introduced. This slowness is present even with all workstations powered off (there are 7). The firmware is up to date. Cisco support reccomends defaulting the box which I am reluctant to do as I beleive it to be a fools errand.
Any thoughts or suggestions?
Thanks!
Bob
Message was edited by: [email protected]
David Hornstein Sat, 02/06/2010 - 21:19
  • Gold, 750 points or more
Hi Bfriend,
Doesn't make sense, the box is infinitely more powerful compared to something like the WRVS4400N.
YES , do what Small Business Support Center suggest , factory reset and try the throughput test from your PC to something likespeedtest
Report on how it's running from a copper Ethernet connection from the SA520W to the Speed test location near you.
regards Dave
Steven Smith Mon, 02/08/2010 - 09:20
What firmware are you running?  Are you running PPPoE through the SA520?
Steven Smith Mon, 02/08/2010 - 09:45
To both of you, are you running your own DNS servers or is the SA 520 running the DNS proxy?
Steven Smith Mon, 02/08/2010 - 09:56
Turn on logging...
Administration -> Logging -> Logging Facility and Severity
Turn on Debugging level for System, Kernel, Network, and Firewall.
Can you get a sniffer from Administration -> Diagnostics -> Packet Trace, do this on the WAN interface.
Use that and recreate the issue with the web pages.
Get the sniffer and the logs and post them here please.
Steven Smith Mon, 02/08/2010 - 12:26
Could you go to Firewall -> Attacks and uncheck the box for block fragmented packets?
Steven Smith Thu, 02/11/2010 - 15:41
Did this disable fragmented backs help?
Related Content
