Ganesh Hariharan Sat, 02/06/2010 - 23:50
Dear All,
Please help me to find the port utilization on Port Channel interface,
With Commands.
Tabrez
Hi Tabrez,
If you want to check port channel utilization show interface port-channel 100 again as it gives you the average of a 5 minute period and if you want port in the port channel the check from the command show etherchannel summary what are ports are ther in portchannel then you need to check via show interface gig 0/21 or 0/22 to check the utilization on those ports.
Hope to help
If helpful do rate the post
Ganesh.H
