MDS9134 Stacked configuration
Feb 7th, 2010
Hello All
I'm currently replacing an existing Brocade SAN with a 9134 based one (not a big site).
Now the 9134 is also available in a stacked config (buying through IBM)  which consists:
1 x 9134
2 x 10Gb port activation Licenses
2 x 10Gb CX4 copper transceivers
1 x CX4 Cable
You obvously buy these in pairs to stack a pair of switches, I've looked around, but i'm still not 100% what you actually get.
Do you still have two switches and a fast ISL or does it appear as 1 bigger switch?  IF one big switch is one the master and thats the one you connect your ethernet management cable into?
Many thanks.
Steven
carl.wallace Wed, 06/30/2010 - 12:43
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman","serif"; mso-fareast-font-family:"Times New Roman";}
After reviewing the various Cisco docs in more detail, I noted some inconsistencies between two different 9100 series hardware install guides (online vs PDF), so I opened a case with Cisco to confirm the behavior of the devices once the cables have been implemented.
This appears to be a case of poorly-written documentation. The switches do not "stack" to create a single logical switch. When connected, the switches will form an ISL** and retain separate domain ID's, which is the behavior I've verified by reviewing the showtech details for two switches connected this way.
EXAMPLE OUTPUT:
SW1
fc1/33     1      auto   on      trunking         c1470  TE      10   --
fc1/34     1      auto   on      trunking         c1470  TE      10   --
SW2
**The 'Cisco MDS 9100 Series Hardware Installation Guide' (OL-21514-01) states:
A 64-port switch can be formed out of Cisco two MDS 9134 Switches by using a copper CX4 X2 transceiver as an Inter-Switch Link (ISL).
Trending Topics: Storage Networking
