Multiple IPSec VPN routing
Feb 7th, 2010
I have multiple site to site VPN and i am trying to make communication between all VPN LAN
means One vpn LAN network can communicate with my other VPN LAN network these both are connected with MY cisco ASA 5510.
i have enabled intra interface security and inter interface security as well but no LUCK
any extra that i have to do please help me out if any one have an answer.
kindly check attached diagram for the same
Thanks a lot for help in advance.
[email protected]
Ivan Martinon Wed, 02/10/2010 - 14:31
Besides the same security commands you need to make sure your traffic definition is correctly defined on the crypto acls for each firewall, as an example see below
Central - Network A
Remote 1 - Network B
Remote 2 - Network C
Remote 3 - Network D
If what you need to do is to allow communication from all remotes using the Central as the hub, you need to do the following
tunnel from Central to Remote 1
A to B
tunnel from Remote 1 to Central
B to A
Tunnel from Central to Remote 2
A to C
Tunnel from Remote 2 to Central
C to A
If you need then Remote 1 to Remote 2 via the central one the cofig would be
Cenral:
A to B
C to B
Remote 1
B to A
B to C
Remote 2
C to A
C to B
And so on...
Let me know if this makes sense, of course the Nat Exempt Acl should mimic this behavior.
