IPCC script editor version 7.5
Feb 7th, 2010
Hi all,
Can anybody provides me with the source of IPCC script editor 7.5 to open .icms script files?
jpsweeney77 Sun, 02/07/2010 - 12:04
You can import the .icms files using the Script Editor application loaded on an Admin Workstation (AW) in your environment.
This of course assumes c:/ is the location of your icm directory.
jpsweeney77 Sun, 02/07/2010 - 12:06
Also, keep in mind that ICM scripts directly reference objects in the configuration database. Therefore, importing from one system to another is not as simple as just importing the script unless all referenced objects exist in both the source and destination configuration databases.
youssef.ahmed Sun, 02/07/2010 - 22:39
I tried to user iscripteditor.exe but after installing it on my PC I entered ICM ip address & left ICM instance blank.After that i got the following error:"can't communicate with web server"
Any ideas?
youssef.ahmed Sun, 02/07/2010 - 22:41
when trying script editor ,i got the following editor"can't connect distributor"
Any ideas?
Edward Umansky Mon, 02/08/2010 - 19:05
Make sure you are running the script editor with a domain user that has configuration access to ICM.
youssef.ahmed Tue, 02/09/2010 - 01:33
Can I use script editor to login to ICM independantly without access to the server itself like IPCC express?
If yes from where I can download script editor?
Does script editor for IPCC express works for opening ICM enterprise scripts?
jpsweeney77 Tue, 02/09/2010 - 05:44
Script Editor is reliant on the connection to the server. Also, the CRS Editor for IPCC Express will not work for opening ICM scripts. Completely different animal.
Edward Umansky Tue, 02/09/2010 - 08:03
No, sorry there is isn't. Internet Script Editor can be run from a remote machine but it still must have an active connection and authentication to a distributor server. You will find that ICM is a completely different animal from UCCX, you will not be able to transfer much of your knowledge of one to the other.
