Mysterious SSH2 password's problem
Feb 7th, 2010
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin-top:0cm; mso-para-margin-right:0cm; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0cm; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
For the last couple of days I have been trying to solve a great ssh2 mystery for my switch ws2950 (ver 12.1(22)ea13):
I put:
(config) Username tadas password cisco
But after show run I get: username tadas password 0 cisco
So the question is: why do i get password 0 cisco  ? And in fact none of my (0 cisco or just cisco) passwords works for logging into switch via ssh2. I am using Tera Term Web 3.1 Though i don't have any problem to connect via com1.
Thank you for your help.
Collin Clark Wed, 02/10/2010 - 12:43
  • Purple, 4500 points or more
In your command, you didn't tell the router to encrypt the password. Something like this would correct that~
username tadas secret cisco
You could also enable password hashing in the config (it does not change the password, only encrypts them for config viewing) using service password-encryption
To view the password in plain text, simply remove the command and you will see the password again. For higher security, use the 1st command above.
Hope that helps.
