ADSL connection
Feb 7th, 2010
Dear all,
I would like to inform me how to check the adsl configuration below, that works. I enter 'show ip route' and get external IPs, but I am not sure whether the router (837) needs more configuration for the completion of the dsl. I want also to configure the ethernet or fast ethernet to connect my laptop.
Cisco#sh startup-config
Using 1432 out of 131072 bytes
version 12.3
no service pad
hostname Cisco
no aaa new-model
ip subnet-zero
ip audit notify log
ip audit po max-events 100
vpdn enable
vpdn-group pppoe
request-dialin
  protocol pppoe
no ftp-server write-enable
interface Ethernet0
ip address 192.168.1.25 255.255.255.0
ip nat inside
hold-queue 100 out
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
hold-queue 224 in
interface ATM0.1 point-to-point
pvc 8/35
  pppoe-client dial-pool-number 1
interface FastEthernet1
no ip address
duplex auto
speed auto
interface FastEthernet2
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet3
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet4
no ip address
shutdown
duplex auto
speed auto
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
ppp authentication pap callin
ppp pap sent-username ########### password 0 ###########
ip nat inside source list 1 interface Dialer1 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
no ip http secure-server
access-list 1 permit 192.168.1.0 0.0.0.255
line con 0
no modem enable
line aux 0
line vty 0 4
password ######
login
scheduler max-task-time 5000
end
Giuseppe Larosa Sun, 02/07/2010 - 23:52
  • Hall of Fame,
    Founding Member
Hello Egeorgopoluos,
configuration looks like correct.
To use the additional FAST ethernet ports: they are treated like switch ports that belong to vlan1.
So the SVI vlan1 has to be configured:
int Vlan 1
ip address 192.168.2.1 255.255.255.0
! the SVI has to be explicitly enabled with no shut:
no shut
ip nat inside
add  the following line to ACL 1:
access-list 1 permit 192.168.2.0 0.0.0.255
this should allow you to connect the PC to one switch port on the router like Fas1 and to access the internet
Hope to help
Giuseppe
egeorgopoulos Mon, 02/08/2010 - 12:44
I cannot see any virtual interface as you mentioned above. The only thing I see is the below (BVI) and when I try to enter it I take the below message:
interface bVI 1
Integrated Routing and Bridging is not configured!
% No interface specified for interface_command
Leo Laohoo Mon, 02/08/2010 - 12:56
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
BVI's are used by Wireless Access Points and 837 does not support this either.
egeorgopoulos Tue, 02/09/2010 - 15:42
do you know how to overcome this problem with the vlan interface ?
