Anyconnect 2.4 and ASA 8.2.1: Unable to connect
Feb 2nd, 2010
Everything is configured as written in the config guides. I have also tried configuring AnyConnect through ASDM, but no success. I had a previously working config for ASA 8.0 and older AnyConnect version, but that is not working either.
I get the following error message while debuging on the ASA:
Validating address: 0.0.0.0
CSTP state = WAIT_FOR_ADDRESS
webvpn_cstp_accept_address: 192.168.10.1/255.255.255.0
webvpn_cstp_accept_ipv6_address: No IPv6 Address
CSTP state = HAVE_ADDRESS
SVC: NP setup
np_svc_create_session(0x36000, 0xD5291340, TRUE)
webvpn_svc_np_setup
SVC ACL Name: NULL
SVC ACL ID: -1
SVC ACL ID: -1
vpn_put_uauth success!
SVC IPv6 ACL Name: NULL
SVC IPv6 ACL ID: -1
SVC: adding to sessmgmt
SVC: Sending response
Unable to initiate NAC, NAC might not be enabled or invalid policy
CSTP state = CONNECTED
webvpn_rx_data_cstp
webvpn_rx_data_cstp: got message
SVC message: t/s=3/16: Failed to fully establish a connection to the secure gateway (proxy authentication, handshake, bad cert, etc.).
and in the Windows Event logs:
Function: CSslTunnelTransport::postSocketConnectProcessing
File: .\SslTunnelTransport.cpp
Line: 1360
Opened SSL socket from 127.0.0.1 to 200.100.50.1
Function: CVpnMgr::OnVpnTunnelInitiateComplete
File: .\VpnMgr.cpp
Line: 3966
Invoked Function: CTlsTunnelMgr::initiateTunnel
Return Code: -32571377 (0xFE0F000F)
Description: NETINTERFACE_ERROR_INTERFACE_NOT_AVAILABLE
Function: CVpnMgr::main
File: .\VpnMgr.cpp
Line: 1484
Invoked Function: CVpnMgr::initiateTunnel
Return Code: -32899056 (0xFE0A0010)
Description: VPNMGR_ERROR_TERMINATING
The VPN client has sent a close message to the gateway:
I have tried to connect from different machines, and I also tried this on an other ASA, but without success.
This is my latest config:
hostname ciscoasa
enable password ******* encrypted
passwd ******* encrypted
names
name 200.100.50.1 internet_ip description External IP
name 192.168.10.0 VPN
interface Vlan1
  nameif office
  security-level 90
  ip address 192.168.0.254 255.255.255.0
interface Vlan2
  nameif internet
  security-level 0
  pppoe client vpdn group ADSL
  ip address pppoe setroute
interface Ethernet0/0
  switchport access vlan 2
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
access-list internet_access_in extended permit tcp any host internet_ip eq 443
access-list office_nat0_outbound extended permit ip 192.168.0.0 255.255.255.0 VPN 255.255.255.0
mtu office 1500 mtu
internet 1500
ip local pool IPPOOL 192.168.10.1-192.168.10.10 mask 255.255.255.0
no failover
global (internet) 1 interface
nat (office) 0 access-list office_nat0_outbound
nat (office) 1 192.168.0.0 255.255.255.0
access-group internet_access_in in interface internet
dynamic-access-policy-record DfltAccessPolicy
eou allow none
aaa authentication enable console LOCAL
aaa authentication http console LOCAL
aaa authentication serial console LOCAL
aaa authentication ssh console LOCAL
http server enable
http 192.168.0.0 255.255.255.0 office
http 0.0.0.0 0.0.0.0 internet
http redirect internet 80
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs group1
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5 crypto map internet_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map internet_map interface internet
crypto ca trustpoint ASDM_TrustPoint0
  enrollment self
  subject-name CN=200.100.50.1,O=XY,C=HU
  ip-address internet_ip
  id-usage ssl-ipsec code-signer
  crl configure
crypto ca trustpoint LOCAL-CA-SERVER
  keypair LOCAL-CA-SERVER
  crl configure
  crypto ca server publish-crl internet 80
  crypto ca certificate chain ASDM_TrustPoint0
    certificate 5b29684b
   quit
crypto ca certificate chain LOCAL-CA-SERVER
   certificate ca 01
   quit
crypto isakmp enable internet
crypto isakmp policy 5
  authentication pre-share
  encryption aes-256
  hash sha
  group 5
  lifetime 86400
crypto isakmp policy 10
  encryption 3des hash
  sha group 5
  lifetime 86400
crypto isakmp policy 30
  encryption 3des
  hash sha group 2
  lifetime 86400
telnet 192.168.0.0 255.255.255.0 office
telnet timeout 5
ssh 192.168.0.0 255.255.255.0 office
ssh 0.0.0.0 0.0.0.0 internet
ssh timeout 60
console timeout 0
vpdn group ADSL request dialout pppoe
vpdn group ADSL localname [email protected]
vpdn group ADSL ppp authentication pap
vpdn username [email protected] password *********
dhcpd auto_config internet
ntp server 148.6.0.1 source internet prefer
ntp server 192.33.96.102 source internet prefer
ntp server 87.229.111.33
ntp server 217.20.135.253
ssl trust-point ASDM_TrustPoint0
ssl trust-point ASDM_TrustPoint0 internet
webvpn
  enable internet
  svc image disk0:/anyconnect-dart-win-2.4.1012-k9.pkg 1
  svc image disk0:/anyconnect-win-2.3.0254-k9.pkg 2
  svc enable
group-policy DfltGrpPolicy attributes
  vpn-tunnel-protocol IPSec l2tp-ipsec svc webvpn
  address-pools value IPPOOL
  webvpn
   svc ask none default svc
username Demo password ***** encrypted privilege 15
prompt hostname context
We are using ASA5510 and Windows XP SP3 (Hungarian) clients.
We also have ESET Smart Security installed, but I tried to disable it before connecting. It doesn't seem to count however.
Anyone can help me?
Message was edited by: polygon
john-caruso Sat, 02/20/2010 - 18:08
I had the same problem.  No contract..no TAC help.  Just backed down to the anyconnect that did not mention DART, which was anyconnect-win-2.3.2016-k9.pkg.
I wanted to use 2.4.1012 for its Retain VPN on Windows Logoff feature, but just setted for the anyconnect-gina-win-2.3.2016-pre-deploy-k9 for that anyconnect version.
Related Content
