What is required to run CUCME 7/8 on 2811
Feb 8th, 2010
Hi all
Can someone please help as I have a cisco 2811 running c2800nm-spservicesk9-mz.124-22.T.bin and want to use it for local phone connectivity with CUCME. Do i just need to install CUCME CME 8.0 files for IOS 15.0(1)XA and the CME 8.0 Updated GUI files for IOS 15.0(1)XA.
Once these are loaded i assume it is just a case of adding the ephones and the users etc.
Simon
simonmossman Tue, 02/09/2010 - 02:34
so as long as I do not use the GUI then I can run CME as normal on this ios? Then just a case of entering all the ephones via CL config? I also need to add a CUE module for VM. Is it simply a case of adding the license files to get this working....after correct config loaded?
