Change IP
Feb 8th, 2010
When I first unpacked my SRW2016, I tried to connect to it using 192.168.1.254 but I could not get in, it is now installed in my network (where we have IP's 10.0.2.1-10.0.2.255) so there is no way I can log into the switch. I also do not have any serial port to connect it to. What would be the way to log into the switch (hopefully using the browser: 80) to change its IP?
Kevin Dorrell Wed, 02/17/2010 - 08:29
  • Green, 3000 points or more
When you say "I could not get in", what was the IP address of the PC that you were using to try and get in?  If it was somewhere on the 10.0.2.0/24 subnet, then I am not surprised the switch did not respond - it probably did not have a route back to the 10 network.  I don't know the SRW2016 switch, but is it supposed to respond to 192.168.1.254 out of the box?
Try configuring a PC with an IP address somewhere on the 192.168.1.x network, and see if you can get into the switch from that.
Kevin Dorrell
Luxembourg
Ganesh Hariharan Wed, 02/17/2010 - 09:37
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
As you said now the ip address is in between 10.0.2.1- 10.0.2.255,now if you know the ip address of the switch (most probabaly in the same range in which your new lan is right now ) then you can directly telnet into the switch and then you can change the ip address of the switch but it is not recommedned to change the ip address of the switch which is in production and if at all you get the ip address of the switch you would need username and password to log in to switch as genrally network administrators used to configure.
Hope to help
If helpful do rate the post
Ganesh.H
