We are getting sporadic "I am sorry, we are currently experiencing system problems" on one queue.
During heavy call volume times when calls are sitting in queue for long periods of time some callers will receive the message "I am sorry, we are currently experiencing system problems" and then get disconnected. We seem to get this on only one queue and it happens when calls are in the queue for longer then 3 minutes. Any good way to troubleshoot this issue? We are on IPCC and Call Manager 4.x
Any assistance is appreciated.
markbatts Mon, 02/08/2010 - 05:48
  • Bronze, 100 points or more
You could  debug your script.You need to installed the Script editor and then run reactive debug while you place and inbound call.
This mught be quite awkward unfortunately as you need to catch the call you make with the debugger when its busy which might be tricky if you have a lot of inbound calls at one time,
mark
lisankejm Mon, 02/08/2010 - 07:56
Are you in the ICM environment? If so,
check the timeout field of the Network VRU script List item in question. The default
is 360 seconds. Try increasing that number  to a higher value. We had a similar
problem and that solved it.
Joe
