LEAP Compatibilty
Feb 8th, 2010
Is the authetenticacion LEAP compatible with a standard wireless network card running in a Windows XP machine (whitout Cisco Wireless Client Software, without Cisco Aironet Utility ).
The Wireless Network is composed by WLC 4404, Cisco ACS.
Overall Rating: 5 (1 ratings)
dancampb Mon, 02/08/2010 - 08:33
No.  LEAP is a Cisco proprietary authentication method and needs a CCX compatible card and supplicant to work.  With an XP PC assuming you are using the Windows Zero Config as the supplicant only PEAP and EAP-TLS are supported.
Trending Topics - Security & Network
