what is % in voice translation rules?
Feb 8th, 2010
Hi all,
I have seen "%" sign used in IOS voice translation rules, but I can't find it in any translation rule config guides. What does it mean and how to use it?
thanks
Overall Rating: 5 (1 ratings)
Paolo Bevilacqua Mon, 02/08/2010 - 10:56
The guide above is about the BTS product, not IOS.
To my knowledge, % is not used in translation rules.
Jaime Valencia Mon, 02/08/2010 - 11:09
Just to add to Paolo's note
Note Wildcard symbols such as the period (.), asterisk (*), percent sign (%), plus sign (+), and question mark (?) are not valid in translation rules. The router simply ignores these symbols when converting a number if they are used in a translation rule.
http://www.cisco.com/en/US/docs/ios/12_2/voice/configuration/guide/vvfpeers.html
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
minghui.qi Mon, 02/08/2010 - 21:07
appreciate your link and quote, but I got this doc from Cisco:
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a0080325e8e.shtml
Wildcard
Definition
Any single digit
0 to 9,*,#
Any specific character
[0-9]
Any range or sequence of characters
Modifier—match none or more occurrences
Modifier—match one or more occurrences
Modifier—match none or one occurrence
it has no reference to %, but it does say * is valid, however from Javalenc's link, * is invalid??!! same with the period "."   Is this because one is voice translation rule and the other is translation rule? I thought they do the same job, just voice translation rule is newer feature.
Paolo Bevilacqua Tue, 02/09/2010 - 02:53
Even Cisco documents may contain errors.
You can use the feedback form on the left to notify Cisco and have it corrected.
