02-08-2010 07:01 AM - edited 03-04-2019 07:26 AM
I have a big issue with the VPN router of a small office (70 users). This router is also use for Internet browsing. The router cpu is around 99% due to the IP NAT AGER process.
CPU utilization for five seconds: 99%/3%; one minute: 97%; five minutes: 90%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
178 2755628 43326 63602 94.43% 93.54% 85.06% 0 IP NAT Ager
sh ip nat tra
Total active translations: 31819 (0 static, 31819 dynamic; 31819 extended)
Outside interfaces:
FastEthernet0/0
Inside interfaces:
FastEthernet0/1
Hits: 725042 Misses: 47287
CEF Translated packets: 750176, CEF Punted packets: 11536
Expired translations: 43226
Dynamic mappings:
-- Inside Source
[Id: 1] access-list 10 interface FastEthernet0/0 refcount 11819
Appl doors: 0
Normal doors: 0
Queued Packets: 0
interface Tunnel1
bandwidth 1024
ip address zzzz 255.255.255.252
ip mtu 1420
ip tcp adjust-mss 1350
keepalive 10 3
tunnel source xxxxx
tunnel destination yyyyy
ip address y.y.y.y 255.255.255.0
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
crypto map WANMAP
interface FastEthernet0/1
ip address x.x.x.x 255.255.255.0
ip nat inside
duplex auto
speed auto
ip nat inside source list 10 interface FastEthernet0/0 overload
What is this ? Are there worms on my LAN ? Is it the virtual reassembling thing that is creating some issues ?
Solved! Go to Solution.
02-11-2010 04:08 AM
To find out the root cause you can enable netflow in your local lan interface and find out whats happening with the traffic transactions.
With that you can come to a solid conclusion or atleast get a clue on what is making or hogging the CPU up.
Configure ip route-cache flow under your local lan ethernet interface and make use of show ip cache flow to check the traffic transactions.
Hope the below link helps u out.
http://www.cisco.com/en/US/docs/ios/12_3/switch/command/reference/swi_s1.html#wp1066187
regds
02-08-2010 11:09 AM
Buggy IOS, upgrade.
02-09-2010 02:32 AM
It's quite new : flash:c1841-advipservicesk9-mz.124-19.bin
02-11-2010 04:08 AM
regds
