02-08-2010 08:10 AM - last edited on 03-25-2019 05:26 PM by ciscomoderator
We are currently running 2 ACS 1110 (?) appliances with code version 3.3(3)-11. They are due to be upgraded to 2 new ACS 1120 appliances with ACS 5.0. I've looked around Cisco.com but don't find a step-by-step guide to such an upgrade path.
My questions are:
Thanks!
Wei
Solved! Go to Solution.
02-08-2010 08:40 AM
Hi Wei,
No, it does not support direct upgrade to 5.x. You need to upgrade it to 4.1 or 4.2 and then to 5.1. I would suggest to work with TAC to get all the software required to get the DB up to the required version for migration to 5.x.
Database can also be migrated.
~JG
Do rate helpful posts
02-08-2010 08:40 AM
Hi Wei,
~JG
