WCS Reporting Internal APs as Rogue
Feb 8th, 2010
I've recently added a few APs to our organization and I'm finding that WCS is reporting a few as rogues.  Should I just acknowledge these as friendly internal or is there something else I should be doing to let WCS know they're internal?
Thanks in advance!
dancampb Mon, 02/08/2010 - 08:39
There are a couple known bugs on this issue.  Really depends on the versions you are running.  In most cases if you enable AP Authentication on the controllers (Security - Wireless Protection Policies - AP Authentication) the AP's in the mobility group will stop being reported as rogues.
Leo Laohoo Mon, 02/08/2010 - 14:17
WLC firmware 4.X and 5.X regularly reports honeypot false alarms.
