02-08-2010 09:06 AM - edited 03-06-2019 09:37 AM
I am trying to track down a packet that seems to be disappearing in our ditribution switch. The sniff shows a destination mac of 000b.450d.000a, however, i do not see this mac address anywhere in the switch. I am seeing the STP VLAN mac as 000b.450d.0000, so I am assuming that the 000a address is a product of STP, but i cannot confirm and am not sure how to find this.
Any help would be greatly appreciated.
Mike
02-08-2010 09:38 AM
Hello Mike,
the OUI is a Cisco OUI
00-0B-45 (hex) Cisco
000B45 (base 16) Cisco
80 West Tasman Dr.
SJ-M/1
San Jose CA 95134
UNITED STATES
there are chances that the MAC address is used as source MAC address on a switch.
Sh module provide the block of consecutive MAC addresses available in a switch, see following example:
sh module
Mod Ports Card Type Model Serial No.
2 8 8 port 1000mb GBIC Enhanced QoS WS-X6408A-GBIC SAD04330B90
3 24 24 port 100FX Multi mode WS-X6324-100FX-MM SAD0606028J
4 48 48 port 10/100 mb RJ-45 ethernet WS-X6248-RJ-45 SAD043209WM
5 2 Supervisor Engine 720 (Active) WS-SUP720-BASE SAD0753097P
Mod MAC addresses Hw Fw Sw Status
2 0002.7e23.e574 to 0002.7e23.e57b 1.3 5.4(2) 8.5(0.46)RFW Ok
3 0001.6477.8e34 to 0001.6477.8e4b 3.5 5.4(2) 8.5(0.46)RFW Ok
4 00d0.d33c.28e8 to 00d0.d33c.2917 1.2 5.1(1)CSX 8.5(0.46)RFW Ok
5 000e.84e4.2dcc to 000e.84e4.2dcf 3.0 8.5(1) 12.2(18)SXF8 Ok
so it should be associated to one port of the switch.
the switch uses different MAC addresses for example as source of CDP, DTP frames and so on.
Hope to help
Giuseppe
02-08-2010 10:09 AM
Any help would be greatly appreciated.Thanks,
Mike
Hi Mike,
000a address can be mac of the switch for a particular vlan where a switch sends a BPDU frame using the unique MAC address of the port itself as a source address, and a destination address of the STP multicast address 01:80:C2:00:00:00.
Just check out and issue a command in switches which are connected show spanning-tree and check what is the mac addrsss of root brieg and own bridge id mac.
Hope to help
Ganesh.H
02-08-2010 11:58 AM
So an unusual item that i have encountered is that a packet caputre shows ICMP replies with a destination address of 000b.450d.000a. The actual physical VLAN interface is 000b.450d.0000. The directly connected router is showing the HSRPvirtual MAC as the arp entry. So I am wondering if anyone has seen anything like this, where the connected router show the HSRP MAC, but the packets are using the phys vlan MAC...???
