"i" remark in CCA Telephony Setup Wizard
Feb 8th, 2010
As I am using Telephony Setup Wizard on a UC 560, an "i" (information?) message appears.
The top bar says, "Phone Loads."
Message: "Removing settingd for phones firmware not in flash and saving configuration"
With "OK" button.
I have pressed the OK a few times to clear the message, but it reappears.
Any Ideas?  Thank you, Paul
Steven DiStefano Mon, 02/08/2010 - 12:41
BUG CSCtd26771 tracking this.
What it is saying is you have "tftp server...." and "load ..." entries in the running config for the phones that
have no phone loads in flash:phones directory. If you click on "ok" in this dialog it should remove all those entries
and should not show again. Now it has a bug where it will keep showing new message box during network refresh
if first one is not clicked. This should be addressed in CCA in an upcoming release.
David Trad Mon, 02/08/2010 - 14:18
Hi Steve,
Glad to hear that this is being resolved in an upcoming release, it is not disruptive but merely annoying :)
Cheers,
David.
