Global call waiting
Answered Question
Maybe I'm missing something obvoius, but I am trying to globally enable call waiting on an SPA9000 system. We are on a single line, when we are on a call and another comes in there is no caller ID for the second call, or an option to pick up. I have looked at the star code settings, but I am trying to find a way to enable CW for everyone without having to constantly type in codes that reset when I have to update the phone system. Thanks in advance for any help you can offer!
System:
SPA9000 @ 6.1.5
SPA400 @ 1.1.2.3 - test build AU CID mix
SPA504G x7 @ 7.1.3a
WIP310 @ 5.0.11
SPA962 @ 6.1.5
Correct Answer by Alberto Montilla about 7 years 2 months ago
Dear Sir;
Yes, this is considered call waiting and it is not supported.
Regards;
Alberto
Dear Sir;
SPA9000 has Call Waiting enabled by default, so this may be something different. Where are the two calls coming from? VoIP? PSTN? Please note call waiting is not enabled on SPA400 PSTN lines.
Alberto
Overall Rating: 5 (2 ratings)
Correct Answer
Alberto Montilla Tue, 02/09/2010 - 07:37
  • Cisco Employee,
Dear Sir;
Alberto
Alberto Montilla Thu, 02/11/2010 - 10:24
  • Cisco Employee,
Dear Sir;
Call waiting is not supported over PSTN lines with SPA400.
Alberto
Correct Answer
Alberto Montilla Fri, 02/12/2010 - 06:07
  • Cisco Employee,
Dear Sir;
Regards;
Alberto
