Limit Bandwidth on 3750 switch to 2Mb
Feb 8th, 2010
I have a client in the same building that would like to purchase 2Mb internet connection. I am handing off ethernet to this client from a port on my 3750. I need to limit this connection to 2Mb. I tried configuring srr-queue bandwidth limit 20, changed the interface speed to 10Mb and ran an internet speed test. The download speed was 2Mb but the Upload speed was still the full 10Mb internet connection. I tried policing on the interface to limit the upload speed (from pc to internet) and that didn't seem to work.
Any ideas?
Greg
Overall Rating: 4.3 (3 ratings)
habadr Mon, 02/08/2010 - 14:07
"Srr-queue bandwidth limit" does not limit inbound traffic, It is used to limit the maximum bandwidth transmitted out of an interface. To limit the inbound traffic on an interface, you must use ingress policing.
Hatim Badr
Layer_Two Thu, 08/16/2012 - 02:20
I have the exact same challenge! 2mb up/down needed on a single port. Download speed works like a charm at 2mb with
#srr-queue bandwidth limit 20 (its a 10 mb line)
However, the upload speed is not limited.
Does anyone know the command to accomplish this?
RG
Marwan ALshawi Sun, 08/19/2012 - 02:54
Have you tried to use bandwidth limit for outbound direction and policing for inbound direction as advised by Hatim above ?
Layer_Two Sun, 08/19/2012 - 02:57
I have tried to implement policing to inbound traffic but it didnt work.
Any suggestion for the appropriate commands to get this working?
Many thanks
Layer_Two Sun, 08/19/2012 - 11:08
Hi Samuel,
Many thanks for looking into this.  I have tried the commands on my 3550 at home and it only worked for download, not upload.
I think the 3550 is not fully compatible with this class mapping as I had to adapt the last command to
service-policy input BANDWIDTH-CUSTOMER_23-PM
If I use service-policy output BANDWIDTH-CUSTOMER_23-PM
it complaints the class is not compatible. Tomorrow I will try on the 3750 and post the outcome!
Many thanks!
Samuel Petrescu Sun, 08/19/2012 - 11:34
On Cisco 3750 policy works only in input direction.
If you want to police traffic Input and Output for a customer, you need two polices.
One applied to the interface where customer is directly connected (like preview one).
One applied to the uplink on the switch.
The customer has to have static IP, so you can identify the customer on ACL
Something like this:
If Uplink for the switch is Gi1/0/1 and IP address for Customer 23 is 10.1.10.23/32
ip access-list extended BANDWIDTH-CUSTOMER_23-DOWNLOAD-ACL
      permit ip any  host 10.1.10.23
class-map  BANDWIDTH-CUSTOMER_23-DOWNLOAD-CM
       description --- Match traffic downloads for customer 23 --
       match access-group name BANDWIDTH-CUSTOMER_23-DOWNLOAD-ACL
policy-map ALL-DOWNLOADS-PM
     description --- Police all downloads, one custemer per class-map ---
     class  BANDWIDTH-CUSTOMER_23-DOWNLOAD-CM
        police 2048000 262144 exceed-action drop
interface GigabitEthernet1/0/1
    description --- Upling to the Edge router ---
    service-policy input ALL-DOWNLOADS-PM
This example is from a production environment
Samuel Petrescu
Layer_Two Mon, 08/20/2012 - 07:05
Hi Samuel,
Brilliant! Kudos! It worked! Many thanks for your support!
Samuel Petrescu Sun, 08/19/2012 - 07:02
Good morning,
You can police upload traffic in this way:
mls qos
ip access-list extended BANDWIDTH-CUSTOMER_23-ACL
      permit ip any any
class-map  BANDWIDTH-CUSTOMER_23-CM
       description --- Match traffic upload for customer 23 --
       match access-group name BANDWIDTH-CUSTOMER_23-ACL
policy-map BANDWIDTH-CUSTOMER_23-PM
     description --- Customer 23 police upload traffic, burst is in byte/sec---
     class  BANDWIDTH-CUSTOMER_23-CM
interface GigabitEthernet1/0/23
    description --- Customer 23 upload 2 Mbps ---
Samuel Petrescu
