ASA 5505 cannot configure FTP and tried just about everything
Answered Question
Feb 8th, 2010
Not sure if my unit is defective or not but I am running on a base license and cannot establish an FTP connection for the life of me. Here is my config;
Thanks in advance....
ASA Version 7.2(2)
hostname ciscoasa
domain-name default.domain.invalid
enable password TGFUt.AsMHJOyury encrypted
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ip address dhcp setroute
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
passwd 2KFQnbNIdI.2KYOU encrypted
ftp mode passive
dns server-group DefaultDNS
access-list 100 extended permit tcp any host 192.168.1.110 eq ftp
access-list 100 extended permit tcp any host 192.168.1.110 eq ftp-data
pager lines 24
logging asdm informational
mtu outside 1500
mtu inside 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-522.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect
timeout uauth 0:05:00 absolute
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet 192.168.1.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.1.2-192.168.1.33 inside
dhcpd enable inside
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:641863a581e04222e46e2ab17a880147
: end
Correct Answer by JORGE RODRIGUEZ about 7 years 1 month ago
Where is the  static nat translation, or port forwarding configuration ?
you have for acl  bellow lines ,  these access list is not even applied to outside interface of firewall.
how do hosts from the outside internet be able to connect to a non-public IP address such as the 192.168.1.110 ?
you need few things to correct in your configuration , first your outside interface  is set  for dynamic ip for ISP to provide public ip address seen in your config as :
interface Vlan2
nameif outside
security-level 0
Number 1-  becuase we don't know what IP address the ISP has dynamically given the firewall you need to know what  address is provided  by issuing on the asa command line  show interface ip brief   and take notes on Vlan2 ip address ...  that Ip address will be the one use for hosts on the internet to be able to connect to your FTP server 192.168.1.110 .
Number 2-  becuase you do not have spared public IP address to use a one-to-one NAT translation  for your ftp server inside to a public IP on the  outside , you need to use  keyword  interface  on both your static port translation and the actual access-list 100  for the firewall to allow  that connection and forward the request to the ftp server on the inside.
static (inside,outside) tcp interface ftp 192.168.1.110  ftp netmask 255.255.255.255
static (inside,outside) tcp interface ftp-data 192.168.1.110  ftp-data netmask 255.255.255.255
Then re-configure acl 100 as bellow and apply it to outside interface
access-list 100  extended permit tcp any interface outside  eq ftp
access-list 100  extended permit tcp any interface outside  eq ftp_data
access-group 100 in interface outside
Lastly   make your your FTP server is indeed running ,  remember that from outside you will use the public IP address  you got from show interface ip brief  output ,  that will be the IP that will be use to FTP from outside to inside.
Overall Rating: 5 (1 ratings)
Correct Answer
JORGE RODRIGUEZ Tue, 02/09/2010 - 20:08
  • Green, 3000 points or more
interface Vlan2
nameif outside
security-level 0
importking Tue, 02/09/2010 - 21:02
Thanks a million Jorge!!!!
I had the access-group 100 in interface outside and removed before I did the copy and paste but the NAT translation threw me for a loop. I had a feeling NAT had something to do with it. I configured a Pix 501 for FTP and did not recall needing to do anything with NAT. Again, thanks for resolving my countless hours of frustration and steering me in the right direction.
JORGE RODRIGUEZ Wed, 02/10/2010 - 06:01
You're very  welcome,  glad to hlelp and  thanks for the rating.
silixious2010 Tue, 11/23/2010 - 05:52
Pity.
I tried the config you reported and I'm getting a bit crazy.
I've an ASA 5505 conected to an access-router C837 that gives to me Internet access through Dynamic IP from my ISP.
This is the config of the ASA
This is the same case the original request
Except there's first an access router, then ASA then internally a Catalyst switch
I've got internal FTP access but not from outside (from internet)
ASA Version 7.2(2)
hostname ASA5505
domain-name UScore.local
enable password
names
interface Vlan1
nameif inside
security-level 100
ip address 192.168.1.2 255.255.255.240
interface Vlan2
nameif outside
security-level 0
ip address 10.10.10.2 255.255.255.252
passwd
clock timezone CEST 1
clock summer-time CEDT recurring last Sun Mar 2:00 last Sun Oct 3:00
access-list 133 extended permit tcp any interface outside eq ftp-data <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
access-list 133 extended permit tcp any interface outside eq ftp <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
access-list 133 extended permit udp host 10.10.10.1 eq syslog host 192.168.1.3 eq syslog log notifications
access-list 133 extended permit ip 192.168.1.0 255.255.255.240 any log
pager lines 24
logging timestamp
logging console notifications
logging monitor notifications
logging trap notifications
logging mail debugging
logging device-id hostname
logging host inside 192.168.1.3
logging debug-trace
logging class auth mail emergencies
mtu inside 1576
mtu outside 1576
ip verify reverse-path interface inside
ip verify reverse-path interface outside
ip audit name BASIC info action reset
ip audit name ATTACK attack action drop
ip audit attack action alarm reset
asdm history enable
arp inside 192.168.1.3 0013.8fc6.1ef8
arp inside 192.168.1.1 0016.ec48.4a16
arp inside 192.168.1.10 0002.b386.94b5
arp inside 192.168.1.9 0011.93e4.15c0
arp timeout 3600
nat (inside) 1 192.168.1.0 255.255.255.240
static (inside,outside) tcp interface ftp 192.168.1.1 ftp netmask 255.255.255.255  <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
static (inside,outside) tcp interface ftp-data 192.168.1.1 ftp-data netmask 255.255.255.255 <<<<<<<<<<<<<<<<<<<<<<<<<<<<<
access-group 133 in interface outside <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
route outside 0.0.0.0 0.0.0.0 10.10.10.1 1
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
username
username
aaa authentication ssh console LOCAL
http server enable
http 192.168.1.0 255.255.255.240 inside
no service password-recovery
service resetinbound
service resetoutside
telnet 192.168.1.3 255.255.255.255 inside
telnet timeout 3
ssh 192.168.1.3 255.255.255.255 inside
ssh timeout 10
ssh version 2
console timeout 0
management-access inside
parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect icmp
tftp-server inside 192.168.1.1 \TFTP
csd image disk0:/securedesktop-asa-3.1.1.29-k9.pkg
csd enable
Cryptochecksum:c76893628ecc39821d3d379f4c7b978b
: end
So it seems to be all right
But it doesn't work
Ok I give you either my C837 config
C837#sh run
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug uptime
service timestamps log uptime
service password-encryption
service sequence-numbers
hostname C837
boot-start-marker
boot-end-marker
security authentication failure rate 10 log
security passwords min-length 6
logging buffered notifications
enable secret
enable password
aaa new-model
aaa authentication login local_auth local
aaa session-id common
no ip source-route
no ip gratuitous-arps
ip dhcp excluded-address 10.10.10.1
ip cef
ip domain name soyuz.local
no ip bootp server
ip inspect udp idle-time 1800
ip inspect dns-timeout 7
ip inspect tcp idle-time 14400
ip inspect name autosec_inspect cuseeme timeout 3600
ip inspect name autosec_inspect ftp timeout 3600
ip inspect name autosec_inspect http timeout 3600
ip inspect name autosec_inspect rcmd timeout 3600
ip inspect name autosec_inspect realaudio timeout 3600
ip inspect name autosec_inspect smtp timeout 3600
ip inspect name autosec_inspect tftp timeout 30
ip inspect name autosec_inspect udp timeout 15
ip inspect name autosec_inspect tcp timeout 3600
ip inspect name ANTI-ATTACK icmp audit-trail on
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
ip ips sdf location flash:attack-drop.sdf
ip ips fail closed
ip ips deny-action ips-interface
ip ips name ANTI-ATTACK
login block-for 3600 attempts 3 within 120
crypto pki trustpoint TP-self-signed-
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate
revocation-check none
rsakeypair TP-self-signed
crypto pki certificate chain TP-self-signed
  quit
username privilege 15 user-maxlinks 2
archive
log config
  logging enable
ip tcp synwait-time 10
ip ssh time-out 60
ip ssh authentication-retries 2
ip ssh version 2
interface Ethernet0
ip address 10.10.10.1 255.255.255.252
ip access-group IDS_Eth0_Out out
no ip unreachables
no ip proxy-arp
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1452
no cdp enable
hold-queue 100 out
interface Ethernet2
no ip address
shutdown
hold-queue 100 out
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
atm vc-per-vp 64
no atm ilmi-keepalive
dsl operating-mode auto
pvc 8/32
  pppoe-client dial-pool-number 1
interface FastEthernet1
duplex auto
speed auto
interface FastEthernet2
duplex auto
speed auto
interface FastEthernet3
duplex auto
speed auto
interface FastEthernet4
duplex auto
speed auto
interface Dialer1
ip address negotiated
ip access-group 139 in <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
ip verify unicast source reachable-via rx allow-default 100
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1492
ip nat outside
ip inspect autosec_inspect out
ip ips ANTI-ATTACK in
encapsulation ppp
dialer pool 1
dialer remote-name redback
dialer-group 1
ppp authentication pap chap callin
ppp chap hostname
ppp chap password
ppp pap sent-username password
ppp ipcp dns request
ppp ipcp wins request
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
ip http secure-server
ip nat inside source list 102 interface Dialer1 overload
ip access-list extended IDS_Eth0_Out
permit ip host 192.168.1.10 any
permit ip any any
logging facility syslog
logging 192.168.1.3
access-list 11 permit 10.10.10.2
access-list 102 permit ip 10.10.10.0 0.0.0.3 any
access-list 111 permit icmp any any redirect
access-list 111 permit icmp any any echo
access-list 111 permit icmp any any echo-reply
access-list 111 permit udp any any eq tftp
access-list 111 deny   ip 127.0.0.0 0.255.255.255 any
access-list 111 deny   ip 192.0.0.0 0.255.255.255 any
access-list 111 deny   ip 172.0.0.0 0.255.255.255 any
access-list 111 deny   ip 10.0.0.0 0.255.255.255 any
access-list 111 deny   ip host 0.0.0.0 any
access-list 111 deny   ip 224.0.0.0 31.255.255.255 any
access-list 111 deny   icmp any any redirect
access-list 111 deny   icmp any any echo
access-list 111 deny   icmp any any echo-reply
access-list 111 permit ip any any
access-list 139 deny   ip 127.0.0.0 0.255.255.255 any
access-list 139 deny   ip 192.0.0.0 0.255.255.255 any
access-list 139 deny   ip 172.0.0.0 0.255.255.255 any
access-list 139 permit tcp any any eq ftp <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
access-list 139 permit tcp any any eq ftp-data<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
dialer-list 1 protocol ip permit
control-plane
line con 0
no modem enable
transport output all
line aux 0
transport output none
line vty 0 4
access-class 11 in
transport input ssh
transport output ssh
scheduler max-task-time 5000
end
C837#
ASA5505#
I dunno what's happening why from an Internet connection with an internal FTP server on LAN 192.168.1.1  this is not accessible
I'll have a look later
While, if someone is able to see where's my fault please tell me
Thanks in advance !!
