F5 Load Balancer Radius integration for Authorisation
Feb 8th, 2010
Hi All
Dose anyone configure cisco ACS for F5 authorisation? Do we need any specific VSA? I am facing issue, authentication is fine but authorisation not functioning.
Sameer Shah
sameer.shah Sat, 02/20/2010 - 01:27
Hi All
After lot of research, found below link on F5 explaining F5 authorisation using tacacs+. So decided to use tacacs instead of RADIUS
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman","serif";}
http://devcentral.f5.com/Default.aspx?tabid=63&articleType=ArticleView&articleId=2316
Sameer Shah
