no-CRC4 framing option for PRI Configuration on cisco 3527 gateway
Feb 9th, 2010
Cisco 3527 videoconfrencing support only below mentioned framing options:-
  • CRC-4
  • Extended CRC4
  • Double framing.
PRI service provider support only no-CRC4. Is there any option to get to PRI with no-CRC4 framing option teminated on 3527.
Please find attached screenshot of the same.
Abhas Jain
paolo bevilacqua Tue, 02/09/2010 - 05:22
  • Hall of Fame,
    Founding Member
Place an ISR router in between 3525 and PRI circuits. Beside teh CRC issues, that will allow you to use PRI for other things beside videoconferencing only.
Related Content
