Tommer Catlin Fri, 02/12/2010 - 09:42
  • Green, 3000 points or more
Here is the guide to Connection:
https://www.cisco.com/en/US/docs/voice_ip_comm/connection/7x/administration/guide/7xcucsag060.html
Even though you have BE,its the same.
They called "Call Handlers"
Typically you setup a CTI route Point in CUCM which points to Unity Connection. (or to voicemail)  Then in Unity create a new call handler with that 4 digit number you assigned in CUCM CTI Route Point.
Then build your caller inputs.
Jaime Valencia Tue, 01/18/2011 - 18:30
  • Cisco Employee,
  • Hall of Fame,
    2011
Because you don't, CUC doesn't even know who is routing the call. It just cares about which DN it's coming from as a FW call.
The same DN you configure in the CTI RP you configure in the call handler OR you leave the call handler DN blank and configure a call routing rule to handle this.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
Related Content
